VoodooTTZ »
https://forums.nicoclub.com/voodoottz-u19458.html
Thu Nov 09, 2006 4:52 am
I have a 1993 TT Z that is in good condition. I have recently replaced the Brake Master Cylinder, Clutch Master Cylinder, and Clutch Slave Cylinder. For some time (I can't remember if it happened before the replacement of above items or not ) every now and then, when I hit the brakes, the pedal drops to the floor, but when I'd react and let them up and hit them again (usually faster so as not to hit whatever I was stopping for) they work fine.
Well, I just discovered that I can replicate this at will now. If I very slowly depress the brakes with a constant pressure (as if trying to stop slowly while coasting slowly to a stop) the pedal will go right to the floor no brakes. As long as you keep pumping very slowly, you will never get brakes. Depress the brakes "normally" or "hard" and you get brakes every time.
Also, I followed the service manual explicitly concerning the brake bleeding procedure, I will likely try to bleed it once again, but I've bled it 3 times now, with no air bubbles. Again, when you brake normally, the brakes work well. Only if you "feather" the brakes will you run into the sinking pedal.
Any help or suggestions would be greatly appreciated!
Thank you!
