1. Vibrations from car when 30+mph in rear.(Pretty decent vibrations, if you have any other suggestions i can check, please let me know)
2. Rear driver side wheel moves up and down(if your facing the wheel lifted up, you can tilt it towards and away from you like positive and negative camber.)
3. Was told, wheel bearing.
4. Bought this exact part http://www.ebay.com/itm/NISSAN-300ZX-90 ... 79&vxp=mtr but for driver side(not sure if it makes a difference)
5. Took all my do-dads off(old hub with bearing inside in my hand detached from car), and have no idea how to get this part into the actual hub. I thought i would only need a press if i just got the actual bearing.
Sorry if it's an obvious answer, I'm still learning. Thanks for the help.
