datsik707 »
https://forums.nicoclub.com/datsik707-u211252.html
Tue Oct 23, 2012 4:11 pm
Just picked up my 1rst z32, 93 n/a 5speed. Having some issues hoping someone can throw out solutions or ideas.
When cruising below 2k rpm, usually in 4th or 5th, or when you let off the gas to cruise, when re-applyng the gas to go it is completely unresponsive, you have to come of the gas and back on a time or three to get it to work again. If it low rpms happens quite often. NOTE: if above 3500 no issues at all, runs strong as hell.
Also, smaller problem vibrations from under the center console between the seats, thinking heat shield bolts or such.
Will probably find more problems as i continue to drive as i just got it last night. Any help appreciated. Thanks guys
