93 240sx won't start
Florida240sx
Swapped engines with one that I had rebuilt. Code is 11 for camshaft sensor which would be in the dizzy but have replaced with another dizzy.Other engine was running fin, removed this swappe din, and now won't start at all. Distributor timing is on. Pulled the valve cover off to check the cams which are good.Car doesn't even try to start. Even using starting fluid it doesn't kick at all..Got spark at plugs, got fuel from injectors... Exhaust is just an open header at the cat...Any ideas?
Florida240sx
Bump
domestickiller
Car: 240sx coupe
does the motor crank over?If so what you need to do is replace the cam sensor clear the codes on your computer and than crank it and see if the codes come back
Florida240sx
I got 3 dizzy's that are bad....
