altralosix »
https://forums.nicoclub.com/altralosix-u17752.html
Mon Sep 19, 2005 4:29 pm
Tonight I got in my car after work and turned the key and heard nothing but a single small click. I had plenty of power and the battery is only 2 years old.
Opened the hood and got my friend to try it and the starter will click once and that's it. We eventually resorted to push starting it and got it running so I could make it home.
Now the strange thing is I've had this problem lately with the ignition. Sometimes I'll turn my key and nothing will happen. If I jiggle the key with it turned the car will start. There obviously seems to be a bad connection in there. So that makes things even more confusing.
Do I try to "hotwire" my car to see if it starts? Does it sound like it's just the starter and the ignition thing is just cooincidence?
Also, when push-starting, I found out I have to have the key turned all the way to start to get it to fire when popping the clutch. I thought as long as it was in the on position it would fire. Took a few tries to figure that out. So if it is indeed a requirement to have the key in the start position, and it started when push-starting it, then obviously the bad connection in the ignition wasn't the problem.
Anyone have any advice or instructions for swapping starters? I've browsed through the copy of the FSM I have and couldn't find much info other than a diagram of how the starter is constructed. I'm sure I could just figure it out, but it's nice to see what I have to do before I do it.
I guess that's it. Thanks guys
edit: Info that may or may not be helpful:152K miles, no idea if the starter has ever been replaced. I've had the car for a year and only replaced a few minor maintenance things, nothing recently. Original engine and everything. 5 speed.
Modified by altralosix at 10:44 PM 9/19/2005
