93 240sx wire location/ relay box
coupe240sxguy
Car: '89 240sx/ '01 mazda 626
93' 240 se hatch- It goes in the relay box near the battery (the passenger side) the wire colors: black\ dark green with yellow stripe\ dark green with aqua stripe\ pink with green stripe\ Missing the wire end with dark green with aqua stripe. It does come off of the relay plug, but no clue as to where it would go. also it is not in the relay box and has no relay in itWould appreciate any help or comments, thank you. I tore up the whole harness under the hood, found two or three wires with the same color, but NO place that was open to hook up.
coupe240sxguy
It also my be going to the a/c. Oh by the way it does help when people help out
Bwana
Car: Denali
I'm not exactly sure what you're asking I guess... You need to know where a dk grn/aqua stripe wire goes in the relay box? First off, go here and download the '94 fsm (closest year, should work fine). There are wiring diagrams in there that should show it. I've just browsed over it, but I can't find the wire you're speaking of. Do you have any idea what it goes to? (ie what isn't working?)
coupe240sxguy
Thanks for the help. I did find where that missing wire goes... to the cruise control.
