KDashy wrote:Ah if only Nissan implemented variavle valve timing for the 240's.
180fan wrote:doesnt nissan have something like that, like on the s14 sr's?
Yes it did, the s14 too and the z32 and a few others but it's NOT VTEC, Variable Valve Timing only adjusts the timing at lower RPMs for a stronger low-end hp but it doesn't increase the valve lift. Nissan’s version of VTEC is called NEO VVL, there’s several cars in Japan that had it, off the top of my head I remember the Pulsar, I believe from the late 90's, it came with an SR16VE and made 170ps all motor (its a lot like the B16A) there was also a limited edition pulsar N1 that was factory tuned (like the in Integra type R) with 200ps out of a 1.6 liter engine it has better HP per liter ratio than and S2000, too bad it was FWD.KDashy wrote:Haha, it might be easier than that, I beleive the S15's used Nissans Varible Valve Timing. Can anyone confirm this?
