centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Fri Sep 01, 2017 4:08 pm
Is that the engine from the s12? FPR takes vacuum, maybe you have a leak from swapping? Did you ground the engine block? I'm just wondering if that would affect the injector pulses. Oh, and fuel return line and evap lines would need to be in correct order and could have been jumbled during a swap...
