positron1 »
https://forums.nicoclub.com/positron1-u27022.html
Mon Apr 30, 2007 3:56 am
So your brake lights stay on constantly after you get out of the car and walk away? If so, it's probably your brake pedal switch, there's a small rubber stopper that comes into contact with the brake pedal switch and it keeps your lights off until the pedal is depressed. Look down on the floor and see if you can find some small broken up pieces of plastic or rubber. The stopper is located at the top of the brake pedal. To replace it just get another stopper and pinch the sides with a pair of needle nose pliers and it slides right into place.
