evlzer0 »
https://forums.nicoclub.com/evlzer0-u10119.html
Sun Oct 08, 2006 7:20 pm
I have a 93 240sx with a KA24DE motor, all basically stock. When I got the car smogged the timing was set to 24-25deg, the smog tech said he would let it slide. No aftermarket parts other than a cone style intake.
Recently I had a ticking noise develop from under the valve cover near the front of the motor. I assumed that it was the guides going out on me like ive read so much about. Now, earlier today after my car spun out unintentionally (lame bald tires) and I started the car up again, I noticed a knocking sound as well. The knock only occurs at about 1500rpm and above. The noise also seems like it is coming from around Cylinder 2 but i cant be sure. I immediately drove the car home and let it cool down. I checked my oil and noticed that it was extremely low. There are no leaks under the car and it is not burning oil, at least not noticably. I refilled my oil until it was at an acceptable level and then started the car again and let it idle and recirculate oil. The noise was still there but not nearly as bad as it originally was. My check engine light is not on also. I have had the car for about 3 months now. Both noises increase with rpms. Do I have a rattling guide and rod knock or just one or the other. If its rod knock wouldnt my check engine light be on? I plan on taking the car to a local shop in the morning, but id like to get any kind of help in figuring out what the problem could be. Thanks.
Modified by evlzer0 at 10:41 AM 10/12/2006
