jetroy240 »
https://forums.nicoclub.com/jetroy240-u85577.html
Thu Feb 28, 2008 5:15 pm
possible egr gallery full of carbon deposits, try to disconnect the egr valve vacuum hose, plug & test drive it. If sputtering goes away, the ports are restricted. You can clean it, if u can remove the 4 freeze plugs at the intake& poked the ports. code 33 is for O2 sensor, possible u got a bad O2 sensor only, to test it, u need a digital volmeter. It's a 0-1 volt range. At engine warmup voltage should be around .3 to .8 volt fluctuations @ idle & high rpm.
Modified by jetroy240 at 6:57 PM 2/29/2008
