93 240sx sr20det swap with auto to manual
bmoreadi
Car: 93 240 HB
i searched but auto to manual guide is a little different..any way here goes.
i have a 93 240sx hatch. my ka is out, doing rust repair on the engine bay before the sr20 goes in, next i need to do the electric side of the auto to manual swap. it said on the guide that i need to find the small two wire female plug which is the park/neutral switch, i have two 2 wire plugs around the fuse box. the inhibitor switch only has one plug on each side. can anyone tell me what colors the 2 wires are for the park/neutral switch. also if im swapping to a sr20 do i just run the green/white from the inhibitor to the reverse light wire??? i dont see a reverse lamp switch on the transmission, the guide does say that there should be 4 plugs where the inhibitor is.. **** man i need some very specific directions.
Jasong
You really need to search. It's all mostly been covered. Look here for a picture, zerothread?id=77784. If you are going from auto to manual some more problems I ran into were that my oil sensor had to be wired to Ka harness along with the speed sensor neither were covered in any of the wiring how to's. And I still haven't resolved the speed sensor issue since after hooking it up I still don't have a speedo. But I haven't had time to look into it yet. On the inhibitor switch You'll use the green/blue stripe to supply voltage to the backup switch and it wiill return by the green/white stripe to the backup lights.
Modified by Jasong at 5:34 PM 12/28/2006
