I've been cleaning up around the underbody looking for rust and havent found anything yet. But yeah, I used the rust converter spray can on it after I sanded it all down. I didnt post any pictures of the process but I did alot of sanding before painting it. What should I do suspension wise if I wanted to put in a ls motor?waxdnuggz wrote:get the body and suspension ready before you need think about an engine like that also what kind of paint did you use there's a type of paint that's called a rust converter that's what you're gonna want to use.
if you just use spray paint its not going to really help. If anything it'll hold moisture and spread the rust. You need to sand to bear metal and primer then spray it at the very least.
As it stands, I still haven't decided what my plans are for this car actually. I want to get her new-car quality at first and then see how I feel about it after that. One things for sure though, and its that form will follow function. I wan't it to be perfect mechanically before I turn her into something that's nice to look at. But don't get me wrong, I still want her to be as appealing as possible.waxdnuggz wrote:Oh an p.s. you dont need that little hole professionally fixed that's tiny. But some sheet metal and cut and bend it how you want and booger weld that thing in. This isn't gonna be a show car I assume mount your battery in the trunk and say f it
Thank god, I had a hunch but I wasn't too sure. I've gotta find the details of his compressor before I get the wrong piece but thanks for putting me in the right direction; I'm pretty unfamiliar with the whole sandblasting concept, would I have to strip the engine bay completely if I wanted to blast the entire thing? I've still got brake lines in and the harness is still there. Here's a pic of what the engine bay looks like currently, any advice on where to go from here would be much appreciated.waxdnuggz wrote:Thats how they do sandblasting is with an air compressor do you have a harbor freight tools near you? Its like 100$ for the attachment tool.
Edit http://m.harborfreight.com/catalogsearc ... sand+blast
I really wanna get the engine bay all prettied up though before I throw the engine in because it's alot easier now, I doubt that i'll make it a show car but I really want to go over the top while i'm preparing it for the engine transplant. So I think i'm probably gonna sandblast the entire engine bay and paint it some random color lol, lime green or a bright blue is what i'm thinking currently because the body is gonna be black in the end and I think it'll add a nice touch instead of murdering it out. This whole process has to be as cheap as possible though because i'm still saving up for the engine too.waxdnuggz wrote:I would take the harnesses out of the engine bay but it's not necessary you can sand blast around them. when you sandblast it's a pretty narrow spray almost like a pressure washer before you sandblast it though you're gonna wanna make sure you get it as clean and grease and dirt free as you can you'll get the best results that way as for the brake lines you don't have to take them outjust put a plastic bag around the master cylinder with the lid on are you planning on sand blasting your entire engine bay or just parts of it it's not really a need to sandblast the entire thing unless you're doing a full-blown restoration
That looks like what I need but seems pricey, could you give me a link of what the part looks like in real life? Cause I might just have a piece of sheetmetal welded inasoomal wrote:http://www.courtesyparts.com/64132-hood ... 62005.html
Yeah you're right, there is some rust in there. I couldn't really get to it with the wire brush.asoomal wrote:
Part 64132
I have a feeling that there is gonna be more rust where the 3 layers of sheet metal meet.
