93 240sx problems
ky240sx07
Car: 93 240sx
well i got my car running now but with the MAF plugged in it hardly run but it will with it unplugged. the problem is i know my EGR isn't on it and there are some vacuum leaks but when i get it to about 2500RPM it won't go any higher like it is hitting a rev lititer or something. i don'tt know what it could be.also the idle isnt completely right but i am more concerned about it not going higher into the RPMs
ky240sx07
Car: 93 240sx
well i looked back over it and a ton of the vacuum lines are disconnected..would that make it like this?
sicride
Car: 1989 KA24ET RPS13
yes it likely would. fix the vacuum lines and plug the MAF back in.
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
The car will not go over 2500RPM without the MAF pluged in and if there a vac leaks with the MAF pluged in then the car will run like ****..
NISTECH
The MAF measures airflow into the engine. All airflow into the engine is suppose to go through this to properly mix the fuel with the air coming in. If you have air entering somewhere else the MAF doesnt see it in turn causing the car to run extreamly lean.
