ranger66 »
https://forums.nicoclub.com/ranger66-u16759.html
Fri May 28, 2004 4:09 pm
My 93 240SX driver side power window will not raise from the lowered position. I checked fuse - fuse is OK and the passenger side widow will raise and lower from the passenger door switch and the driver door switch. I took the driver's side door panel off and looked for any obvious problems with none noted. I bought a switch for the drivers door from a local junkyard and the problem did not change - the passenger window will operate but the driver window will not move from the lowered position. There is no driver side window movement or even noise.
Based on a search of this site, I ran a hot wire and a neutral from the car's battery to the driver side motor lead and I was able to raise the window. So, I have the window raised with the motor but the window does not respond to the original switch or a second switch I bought at a junkyard.
There is another "electrical box" on the driver side door marked amp? Anyone know what this does?
Suggestions? To recap - fuse seems OK and motor apparently is OK. Anyone found a wire that has come loose in a power window factory wiring harness?
Regards,
Scott Carter
