'93 240SX, one headlight sporadically comes on when flipped up.
windsurfing
Car: 93 240SX
Hello,
'93 240SX
Has anyone had experience with one of their headlights coming on sporadically when rotating the lights to the up position. To bypass this problem, I have kept the lights in the up position, and the right light never fails to come on. Switching to new lights produced the same results either way. There are several parts I want to inspect, Timer Assembly-Head Lamp, Light Switch Assembly, and the Headlamp Relay. Any recommendations as to where to begin or any other components to look at?
scottydog
Car: 1992 240sx
I had the same problem. Turned out to be the column switch.
theother1wstolen
Car: 92 240sx Coupe SE
i agree, most likely the switch. and welcome to nico
windsurfing
Car: 93 240SX
Thanks for the info. I will try the switch assembly.
