I Am Chris »
https://forums.nicoclub.com/i-am-chris-u156635.html
Sat Mar 20, 2010 1:30 am
Okay so for starters I have a 93 240SX with a pretty much stock KA from a 91. The only thing not stock would be the Test pipe instead of the Catalyitic converter.
As of now my car has issues that are most noticeable when the motor is warm. I have a hunting idle/rough idle, back fire through the exhaust ( believe I have a leak at the header ), running rich, And a shake in the motor. Also when the car is running it has a sputtering sound from the exhaust.
What I have done so far are as follow. I have checked compression and am at around 155 on all cylinders, I have changed my CTS, checked my MAF, fixed an exhaust leak at the test pipe, checked for vacuum leaks with starting fluid.
Not sure if its of any help but the car is a auto to 5-speed swap and running an auto ECU.
Tomorrow I am going to to be checking the timing and cam position. Also will try to fix the possible leak at the header. Any input from you all is appreciated. Thanks for your time.
