93 240sx ignition coil
TheyCallMeDEE
My car won't wouldn't start before, it would just turn. I change the ignition coil and that solve the problem. Now a month later the car won't start, it's doing the same thing it will start when the car cool. But when the car is up to temp and I cut it off it will just turn, but won't start. I'm thinking ignition coil again but I just changed it or is there anything that might could cause the ignition coil to burn up? Any help will be appreciated!
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
The power transistor may be bad.
TheyCallMeDEE
rogoman wrote:The power transistor may be bad.
will z32 ignitor work with my stock ka?
