Seiferliny wrote:I am worried it is the head gasket because the coolant gushes out upon starting and the hoses seem soft i just replaced on and its soft is that bad? Also there is a little bit of water coming from my exhaust but no smoke is coming out the bubbles look like lil clouse of smoke sometimes too
Modified by Seiferliny at 10:09 AM 3/5/2008
The bubbling when you start it tells me that its your headgasket. Maybe I'm wrong, but i have had them go on two of my 240s, and this was the one of the things that happened everytime.
Key things that happened-Gushed out when i started it-No Heat-Would 'gurgle' (coolant boiling) after i turned the car off.
Replacing the head gasket is not hard at all, and you shouldn't be to worried if it is.
Get a compression tester and check each cylinder. If it is your hg and you need tips, feel free to ask. I can answer 99% of your questions im sure.
