countrytuner »
https://forums.nicoclub.com/countrytuner-u138796.html
Fri Jul 31, 2009 9:33 pm
So i got my ka24de started... ecu is giving me codes 14 and 34... which i believe to be VSS and knock sensor. Im thinking the knock sensor code is because it misses so bad when its running. Seems to not be getting enough fuel for the amount of air thats going to it. revs up to 4000 RPM at quarter throttle but more throttle than that and it revs about 2500 RPM and runs like a toilet. It also wont start unless i prime the intake with some fuel. idles really rough at about 500-800 rpm after it warms up a bit, otherwise it quits at idle. Maybe TPS? but wouldnt it be giving me a TPS code?
