I have a 93 240SX Coupe with a strange transmission problem i think. Intermittently my transmission will get stuck in first gear. It winds up really high to like 6k and wont shift into second until i either come to a complete stop and start driving again. Sometimes I can coax it by letting off the gas then start to accelerate and then it will shift.
It also does the same thing between second and third as well.
Does this make sense?
This problem occurs only intermittently (like once a day). However the other 90% of the time it shifts nice and smooth. My transmission fluid is full and the color is not too bad (pinkish brown).
you clearly read thr wrong thread or didnt make it to the end of the thread. Read the one on wont shift out of first. All the way through. There is a a bunch of tests in that thread. But near the end of it there is reffrence to a rev sensor problem and a way to verify its your problem.
Postby
NISTECH »
https://forums.nicoclub.com/nistech-u7581.htmlSat May 06, 2006 4:12 am
sorry didnt catch your question earlier. No if the speedometer isnt working then unplugging the rev sensor wont help. Instead it will put the car in 3rd gear failsafe.
