93 240sx Auto to Manual Clutch setup?
Nacurtis92
Car: 1994 Honda Civic Si (Selling soon)
1993 Nissan 240sx SE
Hi so i have a 93 s13 and its auto. I plan on buying a rhd s13 sr blacktop clip from a local importer. So I was wondering if the clutch pedal and brake pedal will swap over directly(Of course i will have to drill holes for the clutch pedal) i just wanted to make sure that the jdm one isn't any different. I also will only be working with the parts that come with the front clip. Im assuming that the clutch line is going to need to be swapped out with the usdm 240sx manual one? Can i use the slave and master from the clip? it seems to be around 100 for the usdm KA manual, i was thinking i could just buy a steel braided clutch line and use the jdm master/cylinder? Sorry i would have read the conversion topic but i dont have alot of time. Thanks for all the input :)
Nacurtis92 wrote:Sorry i would have read the conversion topic but i dont have alot of time.
:nono:
Welcome aboard. You're tackling a big job, so slow down and do your homework.
http://www.240sxtech.com/ - See the "Drivetrain" section. There's also some good SR swap info in the Engine section.
Good luck, let us know if you run into any snags... we're here to help.
