Dattebayo »
https://forums.nicoclub.com/dattebayo-u729.html
Sun Feb 20, 2005 6:09 pm
Sounds like the engine is running lean. I would replace the oxygen sensor, then check the Throttle position sensor by wiggling the wires going into it and listening for a "click" noise. If the smoke hurts your eyes, it could be a bad catalytic convertor, but i think that since your plugs look burnt, your air/fuel mix is off.
Before you do any of this, take the car to a mechanic and ask him to test the coolant to see if there is any oil in it. That will tell us for sure.
