xekushnr »
https://forums.nicoclub.com/xekushnr-u16901.html
Fri Sep 11, 2009 6:49 pm
I cant remember offhand, so this is really just a scientific wild a** guess, but it seems like sound advice to me so maybe I'm right.
When the car is warming up it puts the computer in whats called an open loop system. The oxygen sensor data is discarded as its readings wont be accurate until the system has warmed up. Other extraneous info is also ignored, probably including the mass air flow sensor. However when the vehicle warms up and the ECU starts collecting info from the sensors, that disconnected MAFS is not sending any info so the system goes haywire.
I'm willing to bet that your MAFS is the issue here as well. I'm thinking if you replace it everything will go back to normal.
