pr240sx »
https://forums.nicoclub.com/pr240sx-u5499.html
Wed Feb 16, 2005 5:08 am
Check your thermo install, the small hole goes to the top.Even, make that hole a little bit bigger, it helps to bleed more easy!Also, raise the front of the car as high as you can.Put the AC on heat, no need to turn it on.If still doing the same, remove the thermo an go to work, you can still troubleshooting on weekends
