Yea, i'm getting spark on all four cylinders. I tested by holding the spark plug near the head, and they all sparked off the head.
Chezedik wrote:Those results seem fine for a KA24DE w/o WOT, but is the comp kicking on? I would guess that one of the bolt down grounds on the back of the head is supposed to feed heat to the comp on 36, IIRC.
Uh... could you reiterate?
Also, I went through, and there aren't any loose wires or grounds hanging around; i'm pretty confident they're all plugged into their rightful place.
Also, there's a small vacuum hose that I left unattached under the throttle body, and the three vacuum hoses behind the head I didn't know what order they plugged in, so I just plugged them back in using my best judgement. But I doubt these hoses have anything to do with the car not even starting.
As for injection, when I pull the plugs out, I can smell fuel (or at least something rank similar to fuel). Coolant kinda smells rank like fuel too, doesn't it? I remember when it was running, it had coolant problems, and I could smell the coolant. I thought at first it was gas. But I DOUBT coolant could get into the cylinders in any way, especialy since its a brand new head.
How do I check if the computer is coming on? I don't suspect it would sound anything like the old Macintosh startup trumpet sound...
