countrytuner »
https://forums.nicoclub.com/countrytuner-u138796.html
Sat Sep 05, 2009 9:28 am
Hey everyone, So ive been battling with this kade for about a month and a half now. It still wont start unless i prime the intake with fuel, once i do get it running it has rough idle at about 500 RPM, it wont rev past 4000 RPM, and it only runs til about quarter throttle. If i give it any more throttle than that it misses like crazy and only runs about 2500 RPM. While it is running if i hold it at full throttle and give it some fuel manually through the intake it revs up to 6500 no problem. The only code im getting off the ecu is a code 34 for the knock sensor, I pulled the knock sensor and it is toast a new one is on the way. I have 40 pounds of fuel pressure at all times, all the injectors are pulsing, the TPS and MAF are working perfectly and i have continuity through all the wires back to the ecu. I tried an ecu in it and i had the same problem so i just tried a distributor/CAS and that didnt help it either. Im running out of possibilities here. All the ignition is working awesome and the cam and ignition timing are perfect. The only thing i can think of is that the knock sensor is causing it to not run?? Is it even possible for a knock sensor to cause this type of problem? any help would be greatly appreciated as i am running out of ideas and things to try.
