DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Tue Apr 29, 2003 4:16 pm
Sorry, didn't see the point about the fuse being OK...you can check its resistance to be certain.A number of checks you can perform involve the car running, which isn't an option obviously. You might need to have 2 people working on this one to take measurements during the 1st 5 seconds after you turn the key to ON, when the pump pressurizes the fuel rail for startup. You can measure voltage either at the fuel pump controller or at the ECU. Kind of a wash IMO; I'd probably go to the ECU just cause I'm more familiar that way. Check the manual for the pin location...there are a few pages near the back. EF-EC 183 in my manual, and EF-EC 168 for diagnostics. You can try running the pump directly off a power source, but I wouldn't use 12V...maybe 6 or 8V just to see if it turns. Or try measuring the pump voltage from the back of the connector pins right after your helper turns the key.
