92q trip meter function, panel backlight
Drake57
Car: 1992 Q45, 1990 Q45 (parts), 06 Sportster XLC, 85 XJ6, 08 4Runner, 89 Suburban 4WD, 75 Honda CT90
On my 92, the speedometer panel push/twist button labeled A/B reset seems to have no function. I never see any thing at the digital text display. What should it do?
Also the backlight flickers, and occasionally comes on, but for the most part does not come on. Is there a known fix for a mostly non working backlight?
Thanks, Drake.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Yeah, dead lamps behind the trip meter are common...there are two behind it. There's a lighting guide with bulb types in the FAQ sticky, should help you there. The trip meter is actually also the car's status/diagnostics screen, so it's definitely nice to have working. It'll indicate low fuel, low washer fluid, and other conditions as well as showing show when doors are open, and is also used for transmission self-diagnostics.
Drake57
Thanks MOD. I looked but did not see the lighting guide. If anyone can point me to it I'd appreciate it.
Thanks, Drake
goody90q45
Car: 1992 Infiniti Q45 (sold)
Trip odometer bulb P/N is 24860-60U00. I don't think it's listed in the lighting guide.
unknown007
Car: White 1993 Q45 (G50)
Bulbs dying.I got no light in mine.It's not hard to take them out but just take the time if you've never done them.Use the FSM and remember how everything goes.Once it's off you can simple tilt the cluster or better just unplug it and remove the bulbs.It's nothing to hard.
