thirdq wrote:1. Belts and Pullies changed some 2 years back [all belts and the 2 pulleys] dealer parts.2. PS Oil changed every year [roughly 8K miles]
I checked the voltage on the diagnostic connector pin7 and it is steady at 4.9ish.
next I need to check the PS Control Unit - where the heck is the connector for this? Is it beneath the steering wheel area? I am at loss there, any direction as to exactly how to get to the PSCU conenctor would be very helpful [what parts to remove (if any)].....
Also, on which side is the PS solenoid valve - driver or passenger (on the steering rack)?
Thanks
PSCU is buried up above the gas pedal, just to the left of the stereo.I'd look at that as a last resort.The solenoid is on the drivers' side of the rack -on the back w/3 10mm bolts. See if it clicks w/ 12 volts applied and check continuity per FSM.Next I'd look at the VSS output voltage, (pass. side trans. -tailshaft housing, halfway up) .... you can snake 2 wires from the connector into the cabin while you drive it while following the test procedure.Test for voltage. Approx. .03 VDC per MPH, but follow the procedure first.(VSS test towards the end of the EL section)I would bet your VSS is shot. (Mine was, and took the PSCU out with it )
I'd definitely try these two first, unless you like taking the center console and the lower drivers' dash apart, but it's a good chance to clean it. Please write back with any questions or findings.
