1990Q45'r »
https://forums.nicoclub.com/1990q45-r-u34816.html
Tue Jul 25, 2006 10:28 am
Motor mounts can leaking silicon. Check for wetness around mounts.Set park brake and with engine started, put into drive, with foot on brake, raise engine speed to 1500 -1600 rpm momentarily. Have someone watch engine. If mounts are loose/bad the engine will more than just move, more like twist. Being it is a'92, why not replace them if you are in it that deep?
