92Q hesitation
jefmorn
Car: 1992 Infiniti Q45A
1992 Q45 192,000 miles, chainguides replaced at 150,000 miles alone with fuel pump and pfcu. The only mod is a 1994 TCU .I have a ecu code of 34. The car will hesitate from about 1500rpms until it reach the cruise speed that you want. No matter what that speed is. I have cleaned the MAF and check all connectors. Wil the KS cause the hesitation?Thanks Jeff
jefmorn
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Not likely, but have you cleaned TB, IAC and EGR valves, intake plenum? New filters? BG44K?
Must have a maintenance history to even guess.
Modified by maxnix at 7:18 PM 2/3/2007
jefmorn
I have cleaned the IAC, TB, but not the EGR. I will clean it tomorrow.ThanksJeff
Q45tech
ECU in fail safe [regular fuel safety mode] FROM KS failure can often create weird acceleration problems especially when coupled with less than ideal other components.
One always repairs the obvious codes, first then trouble shoot from there.
