pbedrosi »
https://forums.nicoclub.com/pbedrosi-u41754.html
Thu Jan 04, 2007 8:13 pm
I recently replaced my 92Q trans with a unit from 94. Since the trans swap I'm having strange driveability issues. Not sure if they are related.
Trans issues out of the way first.....it won't shift into upper gears until warm. Usually I need to get the engine over 3 grand and let off the accelerator before the trans shifts (hard). Could be gunk in the valve body, or worn seal causing pressure drop when cold. I may put in some trans cleaner and flush out the system. Also, 99% of the time at ignition on I get "trans malfunction" on my trip LCD. I'm still trying to get a hold of 94 TCU just to be sure these are not TCU related. Forgot to add, it won't downshift at full throttle..needs to be manually shifted.
Regarding the engine.....Couple of weeks ago....- Engine idle in park (engine hot) RPM's surged to 2,000rpm for about 10 seconds. Shortly after it did it again. - Cold start RPM is 2,000, and stays up there for over a minute- Highway driving slight pressure relief on the accelerator pedal drops RPM's, need to keep pressure on the accel Pedal to keep from surging (500rpm).
Tonight I felt it even worse in full throttle.......I feel surge at stop light, I mash the throttle wide open (shifter in low) the car accelerates hard than falls flat on its face, very bad, 2,000 RPM drop as if fuel was cut, then on again, off again...all while I have my foot buried to the floor. Felt like the shock was going to rip the driveline...I Get on the highway and if I don't keep any pressure on the accelerator pedal (slight downwards grade) it drops RPM's, it takes some throttle to get it back up again but very abrupt, almost like severe TQ lockup engaging and disengaging.
Car only has 76k miles on it, ran amazingly nice before the transmission failure. The previus owner spent $3k in fuel injector service. Don't know what the freak is going on. Could it be bad 02 sensors? coils? TPS?
