kdkrone wrote:1.) Your response raises the question about the radiator. When does that tend to die? If it does, is it usually repairable like most others or does it need to be replaced?
2.) I think the fluids will be taken care of in the 120K service, but I had already had them on the list, as well as a rebuild of the brake master cylinder.
3.) When does the compressor for the AC tend to go? How about the AC control unit? (I already had Jerry do his magic to restore the LED readout on mine about 25K miles ago)
1.) Be aware there is a sacrifical anode bewtween the radiator and the block. Good idea to replace and inspect for corrosion to get an idea of past coolant condition and performance.
2.) Must mechanically exchange ATF, including pan drop. If using M1 synthetic, use 6 oz. of Lube Guard Red. Exchange your PS fluid also.
3.) Think about evacuatiig AC and replacing drier. When it makes noise, it is replacement time.
Seldom done, but it is critical to clean the fins of radiator, ATF cooler and condenser and the area trapped between them. Same for opening where air is pulled through the alternator. Use compressed air. Check your sunroof and evaporator closet drains. Lube hood hinges and clean and lube sunroof rack, door hinges.
