92Q antenna mount and ecu removal
LAQ
what is the best way to do this?for the mount, i've heard you have to push in on two holes on the top at the same time?
ecu, the glove comp. has to come out or??
Rex
Car: None
Some ECU tips. And I think there's a thread by elwesso about removing the antenna.
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
There is a special tool that fits in the two holes, but the chrome ring just needs to be turned. I use a rubber strap wrench that won't mar any finish(and is left over from my chain guide job).
LAQ
so, once the chrome ring is off, that's it or??
911/Q45
1996 Porsche Turbo
After the ring is off, you pull it out from the trunk after unhooking a hose, electrics and a bolt or two. Very obvious when you remove the trunk liner and look at it.
