92 with terrible accel + idle issues
frenetic
Car: 1993 240sx Coupe
Car runs amazing, idles fine and revs good in neutral. When I put it in gear it cannot accelerate like it should. Up to 2k or 2.5k it is mostly normal but after that there's no torque, and going up any hill is tedious. When I come to a stop and simply brake, the car idles down and dies, however if I give it some gas before it gets to about 1k it will stay idle.
It has new plugs, injectors, wires etc... I am curious if these are two connected occurrences and what may be done to solve them. Thanks
frenetic
any ideas? I need help
cleancoupe
Car: 1990 nissan 240sx coupe
no tourque after a certain rpm sounds like a timming issue make sure your distributor is in the correct spot.
frenetic
it had a bent idler valve which was replaced and since then the only way it gets close to the correct timing is cranking the distributor as far right as possible.. if this is related i will pursue that further. any ideas on what would cause that?
frenetic
frenetic wrote:it had a bent idler valve which was replaced and since then the only way it gets close to the correct timing is cranking the distributor as far right as possible.. if this is related i will pursue that further. any ideas on what would cause that?
sorry meant idler sprocket
frenetic
halp! it's getting colder outside
cleancoupe
that was the same problem i had on mine the owner before me put a new head on it and the timming chain was off by one link (retarted) so i had to turn the distributor all the way to the right (advanced) to try and compensate for it
TannerLDR
Car: 92 Vert
Is this a 5speed or auto? If an auto, sounds like the torque converter
frenetic
5spd
frenetic
OK I am leaning towards timing, which brings up the question of why my timing is needing to be so advanced to idle at all?
frenetic
Any ideas? Timing is still wonky...
Amays U G37S
Car: shoes
Have you checked the brake booster?
I had similar symptoms on my hatch, caused by the brake booster line popping off, or a leak in the system.
jrad240sx
Car: 1990 Nissan 240 SX
turn the crank by hand 4 times cause its a 4 stroke motor then with cylindner 1 cam lobes are facing away from each other on tdc make sure timing marks are lined up then take out dizzy and make sure the little dot on the end is lined up with the open spot that doesnt move on the dizzy shaft. with the valve cover off and timing cover on take light and make sure the dot and open spot are lined up turn dizzt till they are then use timing light to get it just right on 20degrees btdc
