dana0330 »
https://forums.nicoclub.com/dana0330-u137478.html
Wed Apr 20, 2011 6:18 pm
I been driving the Q for awhile after replacing the injectors with the phase 2 injectors and it has been running good, but latley after the engine is warmed up it hesitates from 1500-2100 rpms and is struggling to go put if I press the gas pedal down the rpms go right up and it takes off it is like there is a flat spot in the tps. If I try to power brake it it will go up to 2000 rpms and stop, I can shut off the engine restart it and it will revv past 2000 and brake the tires loose. I put in a used air flow sensor the check engine light comes on but it is for a EGR temp sensor. Could it be a fuel pump control module? do the tps go bad?
Thanks Dana
