az240sx »
https://forums.nicoclub.com/az240sx-u18234.html
Tue Jul 20, 2004 6:21 am
Update on leaking high-pressure hose.
I removed the high-pressure hose and took it to Scottsdale Automotive Specialitsts, in Scottsdale, AZ. For $59 they repaired the hose. They cut the two ends of the hose off and welded new threaded fittings on the ends, installed new hose material.
I reinstalled the hose, refilled the reservoir (almost filled it up with regular power steering fluid until I realized the fluid I drained out was red, and the new fluid was not, who would think they use automatic transmission fluid in the power steering system) bled the system, started it up, test drove and no leaks!
