mosr20 »
https://forums.nicoclub.com/mosr20-u33203.html
Wed Oct 05, 2005 3:21 pm
I found the problem by tracing the schematics in the factory manual.....
apparantly when you do an auto to manual swap...... or at least when you are putting in an sr transmission while doing the swap you have to splice the speedo sensor wires.....
plugs you need to splice are:
Female connector E201 and male connector E 202
I just spliced the yellow/blue stripe wire with the same.........then the yellow/black stripe wire with the same....
cutting off the male E201 connector from the old KA harness makes things easier.........
I never saw this step mention ANYWHERE before so maybe it will be of use to someone else here down the road......
Wish I had seen the info before digging into the Manual..... (but I solved it fairly quickly..... could have been a nightmare though....)
later~
