92 sr-20 charging issues/ NEED HELP! Tried 3 different alternators & no luck~
mosr20
Car: sr20 powered s13 and various Zcars ranging 71 to 96
I'm getting 13.0-14 volts w/3 separate alternators...... (1 s13 jdm one and 2 usdm s13 alts that I made work/drilled out the threads)
The car worked fine before......
it has low voltage upon startup, but once I reved the motor to 3k+ rpms it goes to 14 volts or so ....
I figured it was just a bad alt so Iput in one I had from one of my parts cars...... it got the same result....... and the same results again with yet another alternator .....( both from 91-94 s13s)
I searched and can't find the solution....
i checked to make sure the ground to the alt wasnt touching anything like the ps lines......
I also checked fusable links and other fuses....
please help me get this straighted out.....!!!
thanks!
sd2nola
Car: 1993 240sx
hey, not to make it sound like you dont know anything, when you try to start a car, the starter takes a lot of juice from your batt. after a while your batt should charge. if its not, check a ground wire somewhere. loose ground may be making some drain the batt.
