92 sentra ga16de-clutch noise
skeluhtor
Car: 92 nissan sentra E
ok got the new clutch in and its like nite and day everything feels gr8, what i was wondering is (prob a dumb question) on a ga16de oem clutch i should break it in right?
Second questions is should i be hearing these noises (they r not noticeable when inside car)? when idleing i hear a quiet but high pitch chirping when not pushing pedal, when i push pedal i hear a knocking or chatter that increases with rev's, all sounds disapear when i shift into gear, i read up on these sounds but couldnt really get a clear answer on why all these sounds happen in such a way is it just cause its new? If not should i really worry about it since everything seems to work fine?
thank you for any help
180fan
Car: 89 fastback
clutches need break in time. take care and drive like a granny for a little bit. Ha ha ha.
There may be some other junk in there or something loose.
