92 s13 hud not working at all
rhtuners
Car: 1992 240sx se coupe Ka24DE-T
ok so i am new here but i have been do some research about my hud problem. it does not work at all so now i want to swap it out but i do not know what gauge cluster i should get and out of what 240. some people said that it is this speed sensor some said hook up a volt meter. what to do
CoupedUp
Car: 1993 Coupe
Its all the same just find a cluster from a 91-94 240 and swap them. its a direct swap.
dickie
Car: Killer Turtle
hi!
i'd like to try and help you get your problem taken care of, but first its being moved to the 240sx tech section where it belongs.
dickie
Car: Killer Turtle
now that we're in the correct section, i think its a good time to pimp this link:
http://www.240sxtech.com
this is where the articles written by our members regarding all sorts of topics are collected. check it out next time you run into a problem!
is just your HUD unit burnt out or is it the digital speedo too?
if its the speedo, check this article for help.
if not, try and find a new HUD unit with the wire/plug that goes into the back of your cluster. those are all the same regardless of year. you don't need to swap the entire cluster, but if you decide to, you can keep your tachometer by swapping it to the new cluster.
I recommend testing any cluster or speedo/HUD display you might buy before giving up your money because a lot of them are in no better condition than yours.
good luck!
rhtuners
hey thanks guys im going to the jy tomorrow to look for one. that was a fast reply let you know what happens
dickie
Car: Killer Turtle
cool, if you find more than one that looks to be in good condition let me know.
i have an extra HUD unit i could send you for a working digital speed0
rhtuners
so i went to the jy and found a gauge cluster from a 91 and also wiring harness and it was a straight plug and play the only thing that i had to change was my mileage. thanks again for advice.
slyedog240sx
Car: 93 240sx se coupe, 05 grand cherokee HEMI Power
did you ever push the on off button? the previous owner of my car said mine didn't work when i test drove it. I seen the on off in the cluster pushed it and it was on. been working for seven years. Just a last check before you rip stuff apart.
dickie
Car: Killer Turtle
great to know that worked out for you, i myself am going to try to repair mine with some help from the writeups and articles.
