just the one on the left.. the one on the right is the windshield wiper switchmchkc240 wrote:Are you talking about this one? http://i65.photobucket.com/alb...0.jpg
Yea I kno. But if I wanna replace it I gotta take the whole thing out tho. Right?adrians_s13 wrote:just the one on the left.. the one on the right is the windshield wiper switch
nope. the switch alone is just plug n play. you have to take out the plastic steering column cover to see.mchkc240 wrote:Yea I kno. But if I wanna replace it I gotta take the whole thing out tho. Right?
sheesh... lol... anything else? LOLumm... for the reverse lights, check the fuse, then bulb. after that, if all ok, then follow the wires, and check if the reverse sensor is in tact. the reverse sensor is on the side of the transmission towards the rear of the bellhousing. the reverse sensor has 2 wires that should connect up to a plug on your lower harness.as for your interior lights, ummm... iono.. i guess the same as above mentioned, but take away the part where it connects to transmission.mchkc240 wrote:Also the light in my car doesnt work either. fuse is fine, the light itself is fine.. Also! My back up lights dont turn on either. It's a 5 speed btw.
LOL, I don't know sh*t about tint, although I kinda wish my car had tints sometimes (especially when I want some alone time with the gf ). though I heard windex takes off tint.mchkc240 wrote:LOL! No that's it. High beam. the light inside and back up. LOL! Not that bad? I guess. LOL! Thanks for all your help! Oh btw do you kno how to remove olda** tint? I used heat gun. but after I removed 1 level of tint there's another level down there. And it's hard to remove. Not glue btw. I am supposed to use a steam cleaner do you think spray water while I am using heat gun is gonna work?
