92 Q45T transmission not shifting in d but will shift from 1 2 3 into d, now replacin
mr.beeks
got a replacement transmission after is in how do you clear the codes?ordoes the auto ecu runs a test and adjust?whats next after transmission is in?
thanks for the help in advance...
should I save some of the parts from previous transmission?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Hopefully, you replaced the rear main engine seal and turbine revolution sensor while it was out, and the 5rd motor mount when you reinstalled it. Of course you replced screen, O ring and pan gaskets and one time use bolts prior to exchanging the ATF.
Should be no codes.
mr.beeks
where is the turbine revolution sensor???
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
mr.beeks
changed necessary parts some sensors on the new transmission were different but installed them now working properly it feels even tighter than old one..thanks for quick replies...only had a couple of times the bad transmission on the dash but light went out.Im falling in love w/q45 again...LOL
