92 q45t no dash or nightlights or tail lights (did search)
mr.beeks
i found this thread with no real results in it.
zerothread?id=207802
same sympthomsheadlight OKhigh beams OKbrake light OKsignals OKhazard OKfuse block OK in/outbulbs OKground OK
no dash lightno shifter lightno nightlightsno power comming in
where is the relay located?
thanks in advance..
goody90q45
Car: 1992 Infiniti Q45 (sold)
Check the illumination fuse in the engine compartment fuse box.
mr.beeks
goody94q45 wrote:Check the illumination fuse in the engine compartment fuse box.
done its ok thanks
goody90q45
Done-fixed, or done-checked the fuse already and still have the problem?
If the latter......I had the same problem and couldn't see the break in the fuse except with a magnifying glass. Best to use a voltmeter on the installed fuse rather than trust the naked eye. Good luck.
Kiven422
Car: '93 Infiniti Q45
'94 Infiniti Q45t
Another cause of the tail lights and dash lights going out is the BRAKE SENSORS.
Make sure both (on right side wheels only) are in good working condition or bypassed. Then check & replace the fuses you need. Usually related to the ILL and TAIL LAMPS fuses.
mr.beeks
Kiven422 wrote:Another cause of the tail lights and dash lights going out is the BRAKE SENSORS.
the abs sensors you mean?how to bypass sensors?
I checked all fuses and they are OK no break.I checked all terminals on the rear but get no power.
weather conditions before this happened "lot of rain" it was Ok in the AM but in the PM no more lights.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
From his post I think he means more of the sensors for the brake pads, (The ones that tell you the brake pads need replacing soon).
mr.beeks
sometimes it lights up when I press on the brakes.but thats not all the time.
qship96
Car: 1996 Infiniti Q45
mr.beeks wrote:sometimes it lights up when I press on the brakes.but thats not all the time.
I am not sure anyone who has posted here really understands your problem....you need to figure out how to communicate clearly the symptoms you are experiencing in order to solve this issue
mr.beeks
the problem is I have no nightlights(two amber in front sides, two red in rear sides, no tail lights, no dash or shifter lights)the following test were doneall bulbs are test OK fuses in the car are OKfuses in the engine bay OKheadlights are working OKhazard lights are OKback up lights are OKsignal lights are OKbrake lights are OK
this happened in a rainy day so could there be a short?where is the relay located that controls the nighlights?I was playing with the headlight switch while I was pressing the brake and the lights came on for some reason for a second.no electrical work done lately ex:alarm or stereo.
I still have the problemscould this be more clear so you could understand?can anyone help?
qship96
A little clearer { what you call nightlights, most refer to as parking lights or clearance lights}
I would look at the light switch stalk itself to be sure switch is not worn out. I assume you have checked all fuses,relays, and fusable links???
Considering you said they came on momentarily when you switched them on leads me to suspect the switch itself first.
Infinitiguy19
OK when you turn on just the parking lights, (turning the light switch to the first position) do you here any clicking noise like a relay?
What about the stop lamp switch is that in working condition?
The stop lamp switch is on top of the brake pedal, If you remove that black cover that protects the switches from your shoes or dirt you will see what i mean.
Try the Cruise control, get the car to above 30 MPH and press the Cruise control button see if it activates, Then press the brake pedal to disable the Cruise control.
Does the above work?
Do the rear stop lamps work?
mr.beeks
qship96 wrote:A little clearer { what you call nightlights, most refer to as parking lights or clearance lights}
I said they came on momentaraly when I pressed on the brake pedal.The brake lights turn on when I press the brake pedal.
Where is (are) the fusable links?where is (are) the relays?
will try cruise control and stalk it self it should send a signal on the first click, I dont hear a relay sound while I do this.
Infinitiguy19
I didn't say anything nor do i know much about Fusible Links.
But have no idea if there is a relay for the parking lights, It might just be the Headlamp Relay.
But as I said if you hear just a clicking noise even for a split second then the relay works, I don't know how much better to describe it to short of being their in person or talking you though it on the phone.
But if it turns out to be the relay I have one for you.
mr.beeks
will take another crack at it tomorrow.
Q451990
Check your brake lamp sockets in the trunk. Shorts there between the two lead tips on the bulbs can cause all sorts of issues. Try unplugging each socket assembly one at a time and see if that cures your problem.
Heath
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
RTFSM!
http://www.nicoclub.com/FSM/Q45/
Kiven422
'94 Infiniti Q45t
When in PARK, with headlights on or off, press the brakes and see if you hear a click near the shifter. Like Ppastos said if you hear it that means the relay works... I am not sure about this but from experience I guess hes right.
Do you get the "Brake Pads Worn" warning on the gauge cluster? If so that could mean the brake pads/sensors need to be replaced.
What I did was.... I plugged the brake sensors to the wheel assembly. I cut the sensor off where its supposed to connect to the brake pads and connected the wires together to create a looping signal.
^^Known issue - if someone can better describe it please do--- I think there was a picture around here somewhere too.
This was my problem, nothing else fixed it - I hope it can be of some help to you.
Q451990
Kiven422 - he's talking about a different issue. The brake pad sensors won't have an impact on interior lights, park lights, or tail lights.
Heath
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
I always thought "nightlights" were those little lamps or glowing panels that were mounted on wall sockets.
mr.beeks
maxnix wrote: I always thought "nightlights" were those little lamps or glowing panels that were mounted on wall sockets.
damm ur united states is a really square.thank god for NICO that you get to explore out of it.other names know as
running lightsnight lights
because I cant just refer to tail lights is also the side lightstwo orange in the front sides and two red ones in the rear sides including dash lights.
Modified by mr.beeks at 5:36 PM 11/14/2008
mr.beeks
finally fixed..
all bulbs where OK...
the problem was that one of the sockets had some metal debri and was shorting out.so scrapet it off and it works fine now.so check sockets also they also be a problem.thanks for your help guys...
damm and I almost sold the car for chump change LOL...
Q451990
Q451990 wrote:Check your brake lamp sockets in the trunk. Shorts there between the two lead tips on the bulbs can cause all sorts of issues.
That's why I'm the guru
Glad to see you found it!
Heath
goody90q45
mr.beeks wrote:damm and I almost sold the car for chump change LOL...
...and why I'm known as the undertaker. Careful now.
