92 Q45a
mikeestes
Car: Musica, Sports, Reading
I got a quote for a Hayden external transmission cooler and a flush for $400. Is that a decent deal or should I continue to shop?:cool:
PalmerWMD
Car: 2004 350Z
Info:
The price for the Hayden ( just as good a BM) is about $45-80 dollars for the part, depending on model ( 3 models fit, get the biggest).labor approx 90 minutes w/ a lift (easy job, even I could do it, but would likely be too lazy and find a friend that owes me a favor to do it)
transmission flushes with machine can be had for $90-140 with generic ATF
transmission flush takes 16 quarts ATf plus so adding Mobil 1 ATf will up the flush price a bit.So at 400 they arentr raping you but its certainly not as cheap as it could be.
Fred..:)
The flush if using Mobil 1 should be around $200-$230. Make sure theyre putting the car on a lift and running through all the gears.
The part for a heavy duty transmission cooler was $40 for me, and $60 for a little over an hour's labor.
I guess depending on what part of California you're in, thats not a bad price.
-Jesda
