Replies you shall recieve my good sir!!!!!
Welcome to NICO first off......
Turbine sensor: im pretty sure the transmission has to be lowered, you MAY be able to keep the driveshaft on or maybe just take it off the tailshaft or something..... I know its not as much labor as physically removing the transmission but dont knwo for sure whats involved...
Valve covers: They use liquid gasket (the 94s had a rubber gasket)..... You must take it off and scrub the crap out of it, then put the gasket in the crevace......
Active suspension.... You need to look into a fluid exchange and replace your accumulators at this mileage......
transmission.. You need to have a transmission flush done, and best to have a pan drop with clean and filter exchange... Its been debatable what the order to do it is, but IMO as long as it gets done it doesnt really matter..... You also need to add an external transmission cooler......
For all the terms your not familiar with, you need to read the previous posts, especially by Q45tech... Get you a sandwich and read all the threads in the online mechanic.....
Also, look at our INFINITI ARTICLES section and
http://www.q45.org
