tonyp71 »
https://forums.nicoclub.com/tonyp71-u15878.html
Wed Aug 18, 2004 1:23 am
I've been up all night reading many of the earlier posts, searching for info relevant to my problem. Lots of great info on this site! Still have questions:My 1992 125K mile Qa is not running on all 8. The engine shakes at idle, a couple dead cylinders from the exhaust note...sounds like a race car with a big cam (LOL!) It also seems to be pinging quite badly during moderate acceleration. At idle the tach seems to hold steady but reads low. WHether it's ignition or fuel I don't know. I pulled the plugs. They still looked okay after 65k miles (from vehicle history info)...whitish tannish colored tip...no evidence of fouling and I ordered new NGK Iridium IX's (in lieu of the Platinums--I hope this is ok! After pulling out the plugs I noticed that oil is leaking into the the spark plug holes on both heads...indicating bad valve cover gaskets. Can this oil soaking in the holes be the cause of the ignition misfiring? With respect to the fuel system, is there a relatively easy way to check and test all the injectors without having to remove the plenum...or is this best left to the dealership with their CONSULT device?Also...The car is not smoking, or backfiring or leaking anything visibly...and the I performed a vacuum test reading with a steady needle (approx 18-20 Hg at idle). Any suggestions? I just bought the car and put a transmission, an external cooler and inline filter in her...also a new radiator. I haven't even been able to fully experience the power of this car that everyone in this forum has gotten me so excited about! I'm really looking forward to solving this dilema. THanks for your advice!
