kdkrone »
https://forums.nicoclub.com/kdkrone-u9295.html
Fri Sep 02, 2005 4:03 am
I have a 92 Q45 with 94,000 oringinal miles. My transmission was replaced at the Infiniti dealsership under an extended warranty at 80,000 2 years ago after it failed (I don't understand how the bands work in an automatic transmission but the transmission did not seem to engage.)
The transmission was replaced by Infiniti with a stock transmission, and I installed a separate transmission cooler. All was fine until yesterday until I was pulling onto a freeway and I noticed a sort of "growl" as I shifted into third gear. It was like the sound tires make when they hit a rough patch of pavement but without the vibration. I backed off and the growl ultimately went away when I hit 10mph or so. I accelerated in 2nd gear to 40 or so and there was no problem, so I backed of and then slowly accelerated to 40 allowing the transmission to shift into 3rd. That seemed to reproduce the situation. There was no problem attaining speed of 60-65, just the noise.
Thoughts? Am I looking at another transmission? Should i have it towed to a mechanic asap?
Thanks in advance,Ken K
Modified by kdkrone at 4:16 PM 9/2/2005
