Hey Guys , i have a 92 Q45 with out traction control.. I resently changed injctors because she was missfireing and giving code 51(i think) open injector... Replaced the injector, and drove the car.. the check light was off but the car (that has 2nd gear start), just didnt want to shift out of 2nd untill at high rpms then it would shift to like 4th.. then the check engine lite came on.. i ran back to the shop and the code said Throttle position sensor..
I did search and hav seen some posts on tps.. but none of them came to a conclusion(as in fix it by doing etc.. or change that crap now).. im gonna check the ohms on it.. but its obvious that theres a problem cause its bringing up codes.. No transmission malfunction display(maybe cause the display works when it feels like) soo not 100% sure.. but wen manualy selecting 1 then 2 the car shifts regular.. Please help me out guys thanks
